This professional Philips PLS display delivers Crystalclear Quad HD 2560 x 1440 images. MultiView enhances productivity with active dual connect and view. Webcam enables collaboration saving time and money.
This professional Philips display uses latest PLS Quad HD panel giving you ultra high-res brilliant wide angle images with 2560 x 1440 pixel resolution. With excellent 8 bit color depth combined with 109 ppi density, you can now enjoy professional true color sRGB images compared to limited 6 bit color depth displays with 82 ppi density. Its higher brightness and lower power consumption relative to conventional wide view angle displays ensure you always have brilliant performance, while saving energy too. It's best suited for professional applications like CAD, graphics design, Image rendering etc.
Crystalclear images
These latest Philips screens deliver Crystalclear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Utilizing high performance panels with high density pixel count, 178/178 wide viewing angles, enabled by high bandwidth sources like Displayport, HDMI, Dual link DVI or optional Thunderbolt, these displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images.
PowerSensor
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
Webcam
Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs.
MultiView technology
With the ultra high resolution Philips MultiView display you can now experience a world of connectivity in a comfortable way whether at office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like PC and Notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feed from your set-top box on right side, while browsing the Internet from your notebook on the left is now easy.
Display port with daisy chain
This Philips display employs display port 1.2a Multi Stream Transport (MST) technology with HBR2, which doubles the data throughput to 21.6 Gbps. This enables it to daisy chain multiple monitors, thereby increasing your efficiency dramatically. This daisy chain, multi-monitor capability makes this Philips display especially suitable for use in Finance, Banking, control room and other similar environment.
SmartConnect
With a plethora of connectivity, these Philips displays come equipped with multi connections like Dual link DVI, Display Port, universal HDMI connector, or optional Thunderbolt, enabling you to enjoy high resolution uncompressed video and audio content.
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional.
USB 3.0 super speed
Super Speed USB 3.0 deploys 5.0 gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use the large capacity storage devices. Sync-N-Go technology ensures you don't have to wait anymore for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backward compatible.
Low bezel-to-table height
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
Philips Brilliance 272P4QPJKEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40 W
USB Hub, 2.0 megapixel camera
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
6 ms (grey-to-grey), 12 ms (typical)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
Textured black with black stand
63.9 cm x 24.2 cm x 58 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
3-year warranty
Display Type
Energy Class
Class B
59 kWh
Diagonal Size
27"
Built-in Devices
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base
63.9 cm x 24.2 cm x 58 cm - with stand
8.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , 3 x USB 2.0 , Audio line-in , Headphones , DisplayPort , 2 x HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Power Supply
Internal
Input Voltage
40 W
Power Consumption (Typical)
39.2 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 8.5 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.7 kg
