These amazing Philips screens deliver UltraClear, 4K UHD images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these displays will make your images and graphics come alive. AHVA displays use an advanced technology which gives you extra wide viewing angles, making it possible to view the display from almost any angle. The 10-bit display delivers rich color depth for recreating smooth, natural colors without gradations and color banding. Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker Free technology applies a great solution to regulate brightness and reduce flicker for more comfortable viewing. Enjoy crisp colorful images and audio with simple one-cable connection. An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity in a comfortable way whether at office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like PC and notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feed from your set-top box on right side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your blog. The Smart Ergo base is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. The Philips monitor, thanks to its advanced Smart Ergo base, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
