Discover a high level of interaction with this multi touch LED display. Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality.
Picture quality matters. Regular displays deliver quality, but you expect more. Imagine crisp detail paired with high brightness, incredible contrast and realistic colors for a true to life picture.
Plug & play multi touch
A high level of interactivity is now available thanks to integrated touch technology. More flexibility and optimum simultaneous touch performance coupled with excellent operability opportunities to give you the ultimate in user interaction. The multi touch displays are enabled with automatic touch recognition. The USB connector is HID compliant, providing true plug-and-play operation.
Optical multi-touch
The sensors on the edge of the screen give you perfect clarity whilst at the same time offering multi touch interaction, opening up all kinds of possibilities for interactive applications.
Simultaneous touch points
Enjoy a more interactive experience with touch points at the same time. Ideal for when you have more than one user to interact with your application simultaneously, the 6 touch points offer an extremely cost-effective solution.
SmartPower
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
Designed for 24/7 operation
Because business never sleeps, these signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability.
Philips BDL5556ET 55" Class (54.6" viewable) LED-backlit LCD display - for digital signage
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
HDMI input , VGA input , DVI-D input , Component video input , VGA output , Composite video input , DVI-I , Audio line-out , Audio line-out , LAN , DisplayPort input , Serial , USB , Audio line-in , Speakers output
VGA cable , Serial cable , USB cable
Plug and Play, FCC Class B certified, UL, C-Tick, cUL, SASO, CB, CCC, RoHS, EMF, KUCAS, EPA, EAC
