Impress your audience with the most impactful video wall. With ultra narrow bezel and stunning picture quality, you are sure to create the most memorable visual experience.
Philips Signage Solutions Video Wall Display BDL4777XL 47" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Voltage
86 Watt
Power Consumption Stand by
0.5 Watt
104.49 cm x 10.88 cm x 59 cm
25.5 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
86 Watt
Diagonal Class
47"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode
Dimensions
Without stand
104.49 cm
10.88 cm
59 cm
25.5 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Backlight Life
50,000 hour(s)
Smart Control
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
Speakers output , HDMI , VGA input , DVI-D input , Component video input , 2 x audio line-in , DisplayPort , Audio line-in , Serial input , Serial output , LAN
