Surprise and delight with a professional IPTV. Cost-effective central management, quick installation, and a customizable UI make this a flexible solution. Philips world-renowned picture quality always engages.
Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo and colors to the search bar to increase the visibility of your brand.
Built-in pay-to-view solution
Offer pay-to-view content in any situation-from a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card.
IPTV: provide channels over IP
Provide channels over IP. Install your own user interface (UI), which can be stored on a central server and sent to the TV over IP. Once the UI is on the TV it can also be stored locally. You'll benefit from flexibility and rapid installation whether you're personalizing your Philips Pro System TVs or centralizing system management.
CMND & Control
Run your display network over a local (LAN or RF) connection. CMND & Control allows you to perform vital functions like controlling inputs, updating software, and monitoring display status. Whether you're in charge of one TV or more.
CMND & Create
Take control of your content with CMND & Create. A drag-and-drop interface makes it simple to publish your own content-whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure your stills, text, and video will be up and running in no time.
Philips 43HFL4014 Professional PrimeSuite - 43" LED-backlit LCD TV - for hotel / hospitality
LED-backlit LCD TV - Smart TV
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/345137
Diagonal Class
43"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
Mobile High-Definition Link (MHL)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Internet Streaming Services
YouTube, HbbTV
Commercial Features
VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, IPTV, CMND management, Playready Smoothstreaming, Joystick Control Lock, menu lock
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
2 ports
Philips 22AV1904A/12 remote control, batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class F
Power Consumption (On mode)
44 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
66 kWh
97 cm x 8.2 cm x 54.25 cm
7.2 kg
Energy Class
Class F
44 W
44 kWh/1000h
66 kWh
Diagonal Class
43"
Commercial Use
Series
TV Tuner Presence
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Eco mode
Design
Flame retardant cabinet
Dimensions
Without stand
97 cm
8.2 cm
54.25 cm
7.2 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Direct-lit LED
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
