Easily schedule content to play from USB. Your Philips professional display will wake from standby to play the content you want, and then return to standby once playback is done.
Run your display network over a local (LAN) connection. CMND & control allows you to perform vital functions like controlling inputs and monitoring display status.
Ensure your display never goes blank
From waiting room to meeting room, never show a blank screen. Your Philips display can switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
Philips 43BDL3010Q Q-Line - 43" Class (42.5" viewable) LED-backlit LCD display - Full HD - for digital signage
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 720, 720 x 400, 1152 x 870, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
Motion-JPEG, H.264, MPEG
Supported Audio Formats
WMA, AAC, HE-AAC
Supported Pictures Formats
BMP, PNG, JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-I , 2 x HDMI , USB , Audio line-in , Audio line-out , Remote control , RS-232C , Infrared (IrDA)
