The action leaps from the screen with this Philips 4K Android TV. HDR content looks great, and Ambilight makes movies, shows, and games feel bigger and more immersive. Dolby Atmos gives you premium sound to match the brilliant picture.
With Philips ambilight every moment feels closer. Intelligent LEDs around the edge of the TV respond to the on-screen action and emit an immersive glow that's simply captivating. Experience it once and wonder how you enjoyed TV without it.
Dolby Vision + Dolby Atmos
Support for Dolby's premium sound and video formats means the HDR content you watch will look-and sound-glorious. You'll enjoy a picture that reflects the director's original intentions and experience spacious sound with real clarity and depth.
Simply smart, Android TV
Your Philips Android TV gives you the content you want-when you want it. You can customize the home screen to display your favorite apps, making it simple to start streaming the movies and shows you love. Or pick up where you left off.
Supports all major HDR formats
Your Philips 4K UHD TV is compatible with all major HDR formats, including Dolby Vision. Whether it's a must-watch series or the latest video game, shadows will be deeper. Bright surfaces will shine. Colors will be truer.
HDMI 2.1 VRR and low latency
Your Philips TV boasts the latest HDMI 2.1 connectivity, and the TV automatically switches to a low latency setting when you start playing a game on your console. VRR is supported for smooth fast-action gameplay. Ambilight's gaming mode brings the thrill right into the room.
Slim, attractive design
Looking for a TV that fits with your room? This 4K smart TV is dressed for the occasion! The virtually bezel-free screen goes with just about any interior scheme. While the slim feet make it seem as if the screen is floating above your TV unit or table.
Philips 43PUS7906 7900 Series - 43" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/441226
Diagonal Class
43"
Charcoal grey
Platform
Android TV
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
3840/60p
HDR Format
HDR10, HDR10+, Dolby Vision, HLG10
Frame Rate & Enhancement Technology
Variable Refresh Rate (VRR)
Video Interface
HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
Netflix, YouTube, BBC iPlayer, HbbTV, Amazon Prime Video, Disney+
Picture Enhancements
Pixel Precise Ultra HD
Speaker System
2 speakers
Intelligent Assistant
Google Assistant, Alexa (not available for some languages and countries)
Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control, Clear Dialogue, Dolby Bass Enhancement
Speakers
2 x speaker - 10 Watt
Driver Details
Speaker: 2 x full-range driver
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11n
Connect & Share
Screen Mirroring, SImplyShare
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
USB - side , HDMI - side , Headphones - side , Digital audio output (optical) - bottom , LAN - bottom , USB - bottom , 3 x HDMI - bottom
Internet of Things (IoT)
HDCP 2.3
Power supply
Input Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.3 Watt
Auto On/Off
System standby
Dimensions & Weight Details
Panel without stand - 96.28 cm x 7.81 cm x 55.82 cm x 8.5 kg , Panel with stand - 96.28 cm x 23.57 cm x 58.52 cm x 8.7 kg , Stand - 77.93 cm x 23.57 cm x 2.7 cm
