PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
Low bezel-to-table height for maximum reading comfort
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
SmartImage pre-sets for easy optimised image settings
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
Philips Brilliance B-line 240B4QPYEG - LED monitor - 24"
LED-backlit LCD monitor - 24"
Power Consumption (On mode)
22.3 W
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 15 ms (typical)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V (50 - 60 Hz)
Textured grey
55.5 cm x 24.4 cm x 55 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, DDC/CI, Lead-Free, WEEE, cETLus, RCM, CU-EAC
Display Type
Diagonal Size
24"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartResponse, SmartContrast, SmartImage, WideView, Smart Ergo base, BFR/PVC-free, Mercury free, Zero power switch
Textured grey
55.5 cm x 24.4 cm x 55 cm - with stand
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , DVI-D , DisplayPort , Headphones , Audio line-in , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
MTBF
40,000 hour(s)
Input Voltage
22.3 W
Power Consumption (Typical)
17.4 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 24.4 cm - height: 55 cm - weight: 6.9 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 4.57 kg
