This attractive Philips display with slim bezel and AH-IPS screen gives you awesome, vibrant color images. Mobile HD link allows you to mirror your Smartphone.
Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
AH-IPS technology
This t Philips display uses advanced AH-IPS panels utilizing improved structure resulting in superior color reproduction, response time and power consumption compared to other wide view angle panels. Unlike standard TN panels, AH-IPS panels exhibit least amount of Gamma fluctuation and therefore are able to show consistent color even at 178/178 degrees and in pivot mode. With remarkable performance, it is best suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
SmartImage Lite
SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
HDMI ready
A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input, high quality digital video and audio signals all transmitted over a single cable from a PC or any number of AV sources including set-top boxes, DVD players and A/V receivers and video cameras.
16:9 Full HD
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
TrueVision
TrueVision is a proprietary Philips technology that uses advanced algorithm for testing and aligning monitor display which gives you the ultimate display performance that is 4 times more stringent than Windows sRGB requirements.
Philips E-line 244E5QHSD - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
Glossy cherry black
55.7 cm x 21.3 cm x 42.8 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus
Display Type
Energy Class
Class B
41 kWh
Diagonal Size
23.8"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, TrueVision, 4:3 in Wide, Mobile High-Definition Link (MHL)
Glossy cherry black
55.7 cm x 21.3 cm x 42.8 cm - with stand
3.8 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
External
Input Voltage
28 W
Power Consumption (Typical)
18.2 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.7 cm - depth: 21.3 cm - height: 42.8 cm - weight: 3.8 kg , Without stand - width: 55.7 cm - depth: 4.5 cm - height: 33.8 cm - weight: 3.44 kg
