Open up a new world of opportunities with the Philips Smart All-in-One powered by Android. The expansive 23-inch multi-touch display is perfect for streaming HD videos, music, e-Learning and web surfing to the next level.
Open up a new world of opportunities with the Philips Smart All-in-One powered by Android. Thanks to its built-in advanced optical multi-touch technology, you can now manipulate your content with pinch, zoom, rotate, swipe or scroll. Its generous, large screen frees you from squinting at a small smart display. Reading e-books or newspapers is easy on your eyes thanks to its large font and picture capabilities. Its large touch screen is just the right tool to enable young children to express their creativity with e-painting, learn their alphabet or use interactive educational Apps.
16:9 widescreen Full HD
The Smart All-in-One features a 16:9 Full HD screen for a fully immersive entertainment experience. It's fully future-proof as it supports 1080p signals from all sources, including the most recent Blu-ray and advanced HD game consoles. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Socialize with webcam
The integrated webcam, with superb bright and crisp images, enables you to socialize with your family and friends - just like being face to face. The Smart All-in-One's ultra-sensitive microphone ensures that your voice carries through crisply and clearly. You can hear clear audio from its built-in stereo speakers, or attach your own headphones for private conversations. This simple built-in solution is easy to use and ready to go at any time. Superb stereo sound Immerse yourself with the high-quality built-in stereo speakers.
Expand your storage
Accommodate your ever-growing library. You can expand your storage capacity by adding an external SDHC card or USB flash using the built-in expansion slot.
2 ports USB 2.0 hub
USB hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, web camera, PDA, printer and many other devices which have USB connection available. The conveniently located USB 2.0 hub on the monitor allows USB 2.0 signals to pass through to the computer.
SmartStand
The Philips Smart All-in-One features a SmartStand with maximum recline adjustability and easy one-touch-adjustment. The easy adjustment of the SmartStand enables you to use it in various ergonomic positions. With a recline position of just under 60 degrees, you can now interact with the display naturally to touch and type, or you can use it in an upright position to sit and do some serious work.
Philips Smart All-in-one S231C4AFD - LED monitor - Full HD (1080p) - 23"
