With features like Ergo base, 0.1watt Soft off mode, Dual inputs, SmartImage and SmartControl, the energy efficient Philips 221S3 increases your productivity.
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
Mercury Free
Philips monitors with LED backlighting are free of Mercury content, one of the most toxic natural substances which affects humans and animals. This allows for a eco-friendly display through out its life-cycle from manufacturing to disposal.
SmartPower
SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving. The backlight intensity can be controlled automatically and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
EPEAT Silver
Philips EPEAT Silver certified monitors ensure protection for human health and environment, and are highly energy efficient ensuring low emissions of climate changing green house gases.
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Image, Entertainment, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Screen tilt and swivel
Screen tilt and swivel is a mechanism built into the base permits the monitor to swivel and tilt backward or forward.
70mm height adjustment
The Super Ergo Base is a 'people friendly' Philips monitor base that not only tilts and swivels, but is also height adjustable and pivots to 90 degree, so that each user can adjust the monitor to their personal preference for maximum viewing comfort and efficiency.
Touch controls
Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, Touch control gives the monitor a modern feel.
Dual input
Dual input provides connectors to accommodate input of both analog VGA and digital DVI signals.
Philips Brilliance S-line 221S3LCB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, swivel, tilt
Voltage
50.7 cm x 22 cm x 40 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS, halogen-free
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartContrast, SmartImage, SmartPower, Touch Control
50.7 cm x 22 cm x 40 cm - with stand
4.8 kg
VGA , DVI-D
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Height Adjustment
70 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
16.8 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 50.7 cm - depth: 22 cm - height: 40 cm - weight: 4.8 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.5 kg
