White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
SmartControl Lite
SmartControl Lite is the 3D icon based GUI monitor control software. This allows user to fine-tune most parameters of the monitor like Color, Brightness, screen calibration, Multimedia, ID management, etc. with the mouse.
SmartContrast
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
Mercury free
Philips monitor with LED backlighting are free of mercury content, one of the most toxic natural substances which affects humans and animals. This allows for an eco-friendly display through out its lifecycle from manufacturing to disposal.
ENERGY STAR
ENERGY STAR is a US EPA sponsored energy efficiency program also adopted by many other countries. ENERGY STAR certification ensures that you are buying a product which meets the latest power efficiency standards which operates with maximum power efficiency at all operational levels. For example, in sleep mode ENERGY STAR requires less than 1 W power consumption, whereas Philips monitor consumes less than 0.5 W.
Philips V-line 196V4LSB2 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
Textured black, glossy black
44.3 cm x 20.1 cm x 34.9 cm
2.98 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, BSMI, GOST, cUL, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
3-year warranty
Display Type
Diagonal Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, SmartContrast, 4:3 in Wide
44.3 cm x 20.1 cm x 34.9 cm - with stand
2.98 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
14.13 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7
Dimensions & Weight Details
With stand - width: 44.3 cm - depth: 20.1 cm - height: 34.9 cm - weight: 2.98 kg , Without stand - width: 44.3 cm - depth: 4.8 cm - height: 27.9 cm - weight: 2.66 kg
