Video wall displays no longer need to be limited to just walls and carts. With the Peerless-AV DS-VWT955-2X2, a video wall display can now be mounted to a ceiling. The tool-less micro adjustable design provides placement of four displays in a 2 x 2 configuration, neatly aligned on the same plane. The tilting adjustment options of 5, 10, 15 and 20 degrees means you can be assured of the perfect viewing angle for your application. It is ideal for department stores, entertainment venues or other large public areas. Compatible with Peerless-AV fixed length and adjustable length columns.
