Increase your mounts' compatibility with the ACC-DSVW8X4 by Peerless-AV. This low cost adapter rail solution for displays with VESA 800 x 400 mm mounting patterns allows the display to be mounted with the video wall mounts. In addition, keeping the adapter rails located near the corners of the display allows the mount to independently fine tune each corner for precision alignment, giving your video wall a seamless appearance.
