            The HP447 series flat-panel desktop swivel mount offers a secure, functional and sleek desktop surface mount for hospitality applications. It is designed to seamlessly connect to a variety of flat panel screen models while its deeper adapter plate allows for easy access to cable input connections. The built-in adapter plate is VESA 200 x 100 and 200 x 200 mm compliant and comes with security screws to deter tampering and theft. The mount provides more than just aesthetics and theft deterrence with its swivel range from 0º to 360º it delivers virtually any viewing angle within its diameter.
