            From any angle, this wall mount reflects remarkable form and function. Extending the flat panel display up to 27.55" (700mm) from the wall and allowing for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling and 1" (25mm) of vertical adjustment features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a desirable cable management system, centering the TV on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Mounts.
