Designed to support flat panels ranging from 22" to 50", this adaptor accommodates a wide variety of screen sizes, making it a suitable choice for diverse display needs.
Robust construction
Crafted from cold-rolled steel and finished with a durable powder coating, this mounting component ensures a secure and stable support for your flat panel, supporting up to 68.2 kg.
Flexible mounting options
With a comprehensive range of flat panel mount interfaces from 100 x 100 mm to 400 x 400 mm, it offers flexibility in mounting, catering to a multitude of installation scenarios.
Peerless Universal I-Shaped Adaptor PLP-UNM mounting component - for flat panel - black
Mounting component
Mounting Components
Mounting adapter
41.9 cm x 1.8 cm x 42.5 cm
1.95 kg
Recommended Use
Flat panel
Recommended Display Size
22"-50"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 100 mm, 400 x 200 mm, 400 x 400 mm
Max Load Weight
68.2 kg
Material
Cold-rolled steel
5-year warranty
41.9 cm
1.8 cm
42.5 cm
1.95 kg
Material
Cold-rolled steel
AV Furniture
Mounting component
Mounting Components
Mounting adapter
Recommended Use
Flat panel
22"-50"
Max Load Weight
68.2 kg
Finish
Powder coated
Limited warranty - 5 years
