            The Peerless-AV SmartMount Cart was designed to safely mount, move, and store the 50.5" Microsoft Surface Hub 2S/2X. The cart is load rated up to 65lb, sits at Microsoft's recommended viewing height (55"), and offers vertical adjustment so the display can be positioned at incremental heights 48" to 60" from the floor. The design of the cart allows the display to rotate from landscape to portrait without interference. The cart also provides clearance to the removable compute cartridge so this can be upgraded without removing the display. Locking 4" casters provide a stable foundation for touch applications, while cable management channels completely hide the cabling inside the uprights. Ideal for corporate, education or hospitality applications, the SR560-HUB2 is the perfect mobile solution for the Microsoft Surface Hub 2S/2X.
