Back
Accessories
Peerless-AV Large Flat Panel Tabletop Stand with Black Base
Quicklinx:
9Z3DWS00
Mfr#:
PLT-BLK
Back
This product is ideal for 32-50" LCD and plasma screens up to 68kg (150lbs).
Peerless PLT-BLK mounting component - for flat panel - black graphite laminate
Mounting component
Mounting Components
Desk stand
61.6 cm x 35.6 cm x 57.5 cm
Adjustments
Tilt
13.6 kg
Recommended Use
Flat panel
Recommended Display Size
32"-50"
Max Load Weight
68 kg
Material
Steel
Black graphite laminate
5-year warranty
61.6 cm
35.6 cm
57.5 cm
13.6 kg
Material
Steel
AV Furniture
Mounting component
Mounting Components
Desk stand
Recommended Use
Flat panel
32"-50"
Adjustments
Tilt
Max Load Weight
68 kg
Scratch-resistant, swivel adjustment
Limited warranty - 5 years
