With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application. The modular mount line was developed with the professional AV installer in mind. Designed around a 2" (50 mm) diameter pole, the line is ideal for projects as well as for upgrading existing installations. The MOD-FPMS2 tilt box is the perfect solution for mounting displays installed using the modular series line of mounts.
