The HP432-002 flat panel desktop swivel mount is designed as a functional and secure solution for desktop-mounted displays in hospitality applications. The mount directly bolts-down to the desktop surface for safety and security, with security screws that attach the display to the mount adaptor plate. With up to 30 degrees of swivel each direction, this mount provides a low-cost solution to fit a variety of needs and room configurations.
