Back
Accessories
Peerless-AV Corner Bracket (Without Mount) up to 90kg - Black
Quicklinx:
9Z09WS00
Mfr#:
CM60
Back
The CM850 allows screen to fit in corner where space is limited.
Peerless CM60 mounting component - for flat panel - black
Mounting component - wall-mountable
Mounting Components
Adapter plate
15 kg
Recommended Use
Flat panel
Recommended Display Size
40"-60"
Max Load Weight
90.8 kg
Material
Cold-rolled steel, fused epoxy
OneMount Flat Panel Modular Wall Mount ONE-TP; PARAMOUNT Universal Flat Wall Mount PF640, PF650, PF660; PARAMOUNT Universal Tilt Wall Mount PT640, PT650, PT660; SmartMount Universal Flat Wall Mount SF640, SF650, SF660; SmartMount Universal Tilt Wall Mount ST640, ST650, ST660
15 kg
Material
AV Furniture
Mounting component
Mounting Components
Adapter plate
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
40"-60"
Max Load Weight
90.8 kg
Peerless OneMount Flat Panel Modular Wall Mount ONE-TP , Peerless PARAMOUNT Universal Flat Wall Mount PF640, PF650, PF660 , Peerless PARAMOUNT Universal Tilt Wall Mount PT640, PT650, PT660 , Peerless SmartMount Universal Flat Wall Mount SF640, SF650, SF660 , Peerless SmartMount Universal Tilt Wall Mount ST640, ST650, ST660
