More than just an RC car the Jumping Sumo Mini Drone from Parrot can perform acrobatics including half- and U-turns cruise at up to 4. 5 miles per hours and jump up to 31. It is controlled using the Parrot Free Flight 3 app with a smartphone or other Wi-Fi enabled mobile device available separately. A built-in 640 x 480 resolution 15 fps camera allows you to see a first-person view as the Jumping Sumo rovers around. Plus a USB port on top allows you to connect a flash drive to make a video recording of your adventures. Two wheel settings allow you to choose between a wide stance for speed and stability or a narrow stance for maneuverability.
