Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. With every film or program, you'll marvel at the deep blacks, bright whites and vivid colors in all their full glory.
Content stored in a USB memory stick can easily be played back on VIERA's large screen. A wealth of customization functions let you add background music and effects.
HDMI 2.0
So you can enjoy the full effect and impact of 4K Ultra HD. VIERA offers HDMI 2.0 connectivity. Simply hook up your various devices - such as a Blu-ray recorder or gaming consoles - via HDMI 2.0 to the TVs dedicated terminal. You'll get uncompressed picture quality that remains brilliant with vivid colors, strong contrasts and sharp contours. With HDMI 2.0. 4K UHD has never looked better.
Panasonic TX-40CX400B VIERA - 40" LED-backlit LCD TV - 4K
LED-backlit LCD TV
Diagonal Class
40"
3D
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
200 Hz RMR
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
LAN
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Internet Streaming Services
Internet Apps (Simple)
USB
3 ports
Panasonic RC48125(RC5) remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
Power Consumption (On mode)
63 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
91 kWh
91.2 cm x 6.5 cm x 53.2 cm
LED-backlit LCD TV
Energy Class
Class A
63 W
91 kWh
Diagonal Class
40"
Series
VIERA
3D
TV Tuner Presence
Video Interface
HDMI Ports Qty
4 ports
Modes
Dynamic Picture Mode
Design
Ultra Narrow Bezel Concept
Dimensions
Without stand
91.2 cm
6.5 cm
53.2 cm
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
200 Hz RMR
Direct-lit LED
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Chrome
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
HDTV Tuner
Video Features
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
Audio System
Surround Mode
Network & Internet Multimedia
LAN
DLNA
Connector Type
4 x HDMI input - side , 3 x USB 2.0 , SCART , Digital audio output (optical) , Headphones , Composite video / component video / audio input , LAN
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.5 Watt
Dimensions & Weight Details
Panel without stand - 91.2 cm x 6.5 cm x 53.2 cm , Panel with stand - 91.2 cm x 27.1 cm x 59.3 cm
