This stylish design blends in with surrounding spaces and fills the screen with images. The 6.3 mm (0.25") bezel width of the LF80 series is less than half the 16 mm (0.7") bezel width of the LF60 Series. And the slim design makes the depth only 57 mm (2.3"). Since the LF80 series blends in with almost any surroundings and the screen is nearly filled with images, this display has a powerful, eye-catching impact.
Performance with 700 cd/m2 of brightness is required for some signage and other professional applications. This allows images to be beautifully displayed even in large, brightly lit spaces, such as train stations and airports.
There is very little change in color, compared with the VA panel, when the screen is viewed at right or left angles, so the images are crisp and clear. This is ideal for providing correct information to places with a lot of people present, such as public spaces and facilities.
