Power Supply Input
DC 15.6 V [Do not use other than the specified AC adaptor (Model No. CF-AA5713A)].
Expansion Bus Connector
24-pin
USB Port
USB 2.0 × 2 / USB 3.0 × 2
LAN Port
RJ-45 × 1
HDMI Port
HDMI × 1 For exclusive use with HDMI standard
VGA Port
Mini Dsub 15-pin female (Analog interface)
Serial Port
Dsub 9-pin male
Physical Dimensions
Approx. 400 mm × 55 mm × 290 mm, (Width × Height × Depth) {15.8" × 2.2" × 11.5"}
Weight Approx.
2.0 kg {4.5 lb.}
