The Panasonic KX-MB2000 Series of compact multi-functional printers are an excellent choice for small offices and remote home offices. They feature a 24-ppm high-speed printer, diverse copy functions, a high-resolution color scanner with up to 9600 dpi (interpolated), and a 33.6 kbps Super G3 Fax. They also come bundled with the Easy Print Utility, which includes a print image control function that simplifies the production of complex documents. The compact KX-MB2000 Series body contains the functions you need for business.
