The 3MOS System PRO is comprised of the F1.5 LEICA Dicomar Lens, the 3MOS Sensor, and Crystal Engine Pro II. In addition to the excellent color reproduction and high-resolution that the 3MOS system is known for, the 3MOS System PRO delivers greatly enhanced image quality, especially in dimly lit situations, and achieves twice the sensitivity. Horizontal resolution of 1080 TV lines makes it possible to shoot high-resolution Full-HD images that express small details.
A manual ring is provided to meet the needs of photographers who want to have full control over operations. The large manual ring allows intuitive operation of iris, zoom, focus, shutter speed and white balance. The Level Gauge visibly assists you to shoot straight with horizontal and vertical level gauge. The extendable 263,424-dot equivalent EVF is easy to use and convenient for focusing and other adjustments. It makes it easy to see the shooting scene under bright sunlight that makes the LCD difficult to see.
