Despite its light weight and compact dimensions, the PT-VW355NAJ outputs 4,000 lm of brightness for spectacularly clear and brilliant images.
High 12,000:1 contrast
A iris mechanism optimizes light output according to content. Blacks are deep and rich while colors and highlights are reproduced with realism.
Daylight view basic
Panasonic's daylight view basic technology achieves sharp, easy-to-see images by clearly reproducing the details in dark areas of the image, which were previously difficult to see in brightly lit rooms. A built-in sensor measures the ambient light, and daylight view basic function adjusts halftone color and brightness levels according to the surrounding illumination.
Quiet operation
The quiet design keeps noise levels down to a low 29 dB on Eco mode with the cooling fan hardly audible, minimizing distractions during presentations.
Low power consumption on standby
With Standby mode set to Eco, standby power consumption is a mere 0.5 W. This lowers running costs and helps to reduce environment impact.
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
2 x AAA batteries, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
Power Source
AC
320 Watt
Power Consumption Stand by
14 Watt
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software, Wireless Manager Mobile Edition 6.3
