Equip your teams to represent your business with a polished, professional appearance. Symmetry series antimicrobial Galaxy S23 case integrates an antimicrobial additive that helps inhibit microbial growth and helps defend the case exterior against many common bacteria. Your teams experience full phone functionality while achieving maximum productivity with Symmetry series guarding their phones. Easy to remove and install your teams have the confidence their critical business tech is protected and you have the assurance they are making the right impression.
Used stock
All used stock comes with a 90 day warranty.
Condition: Customer return - item has been used and shows signs of use
Ref: H6V9 051335
- Accessories:This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- Packaging:This part of the stock item is not present or functional
- Functional:This part of the stock item is present and in good condition
- Software:This part of the stock item is not present or functional
- Manuals:This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
