Slip into the sleek case for stylish protection that expresses your personal style compatible with both iPhone 7 and 8.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Stylish designs: eye-catching colors dress up your device
- Slim profile: sleek design slips easily into pockets and purses
- Screen bumper: raised, beveled edge helps protect touchscreen
- Easy installation: one-piece design slips on and off in a flash
