Put three layers of rugged protection between your tablet and the world. This case is made to protect from heavy use, drops and tumbles.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Multi-layer iPad Pro case for maximum protection
- Screen protector guards touchscreen against scratches and scrapes
- Port plugs lock out dust and dirt
- Included shield stand comes equipped with a convenient slot for your Apple Pencil
- Apple Pencil and iPad not included – case only
- Does not work with Apple Smart Keyboard or Apple Smart Cover
