The X319USTir, is perfect for businesses, schools and colleges. It is bright and uses IR interactive technology, enabling people to work simultaneously on the screen using pens. The high throw ratio means that it can project images from a small distance. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter.
