Created for home entertainment, the bright H182X is perfect for watching TV shows, sports and movies or playing action-packed games on a huge screen. With a built-in speaker and HDMI input the H182X is easy to setup and use.
This Optoma projector can display true 3D content from most 3D sources, including 3D Blu-ray players, 3D broadcasting and the advanced game consoles. Support for rapid refresh rate provides ultra-smooth flicker free images.
HD ready
HD resolution gives you sharp and detailed images from HD content without downscaling or compression, being perfect for watching high definition movies, TV shows and playing video games.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
Amazing colors
For vibrant, natural looking images, the Optoma projector incorporates BrilliantColor multi-color processing technology.
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers.
Long lamp life
The Optoma projector lamp lasts for hundreds of hours, allowing you to watch movies every day for years.
Optoma H182X - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Contrast Ratio
23000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x USB - 4 pin mini-USB Type B , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x S-video input - 4 pin mini-DIN
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
