The VP-10 recorder has omni-directional stereo microphones in order to securely capture every sound and voice, whether recording from your pocket, clipped to your notebook, or from anywhere else. The recorder has low noise, high-quality microphones in its compact slim body.
The unique "Anti-Rustle filter" technology identifies the difference between a voice and a rustling sound from its characteristics, and effectively suppresses the noise only. This enables powerful exclusion of the rustling noise generated when recording from your pocket, to achieve a low-noise, clear sound.
You can silently and quickly activate the recording with one-touch even in your pocket, thanks to the REC slide switch. You can start recording without making the other party self-conscious. Moreover, even when the power is off, you can start recording in an instant with just a touch, so you will never miss a recording opportunity.
