Featuring durable high-quality finish and extra-wide field of view of 65° the DPS I let you discover the expansive nature around you with ease.
Olympus DPS I - binoculars 8-16 x 40
Binoculars
Dimensions
18.2 cm x 5.8 cm x 15.2 cm
0.79 kg
Special Functions
Zoom
Magnification
8-16 x
Objective Lens Diameter
40 mm
Eye Relief
12 mm
Prism System
Porro
Lens Coating
Coated
Max View Angle
5 degree(s)
Optical System
Binoculars
Length
15.2 cm
18.2 cm
5.8 cm
0.79 kg
Optical System
Special Functions
Zoom
Magnification
8-16 x
40 mm
Prism System
Porro
Eye Relief
12 mm
Eye Width Range
60-70 mm
Focus System
Center focus
Lens Coating
Coated
Lens Construction
4 groups / 6 elements
Min Focus Distance
10 m
Focus Adjustment
Manual
Max View Angle
5 degree(s)
Magnification / View Angle
8 x / 5 degree(s) - field of view 87 m / 1000 m - relative brightness 25 , 16 x / 3.4 degree(s) - field of view 59 m / 1000 m - relative brightness 6.3
