The wide carriage ML5791 is ideal where fast printing, reliability, versatile paper handling and superior quality text is essential. Whether you are printing invoices, purchase orders, spreadsheets, picking lists, call log slips, tickets, receipts or multi-part documents, the ML5791 keeps transactions smooth and your customers happy.
The ML5791 has been developed with eco-friendly technology. With power consumption of just 1.5 w in sleep mode, your running costs and energy consumption are kept to a minimum, as well as reducing your carbon footprint.
More paper paths give you flexibility. The three tractor feeding paths handle multi-part forms and continuous paper from either the front, rear or bottom. The two friction feeding paths handle cut-sheets, cards and envelopes from either the front or top.
A selection of pull and push tractors allow permanent stationary loading, for use on demand and handle multi-part and continuous forms more efficiently.
