Up to 32 ppm - B/W - A4 (210 x 297 mm) , Up to 22 ppm - colour - A4 (210 x 297 mm) , Up to 17 ppm - B/W - A3 (297 x 420 mm) , Up to 12 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
Parallel, USB, LAN
PowerPC 750CL 700 MHz
RAM Installed (Max)
128 MB (728 MB)
Language Simulation
PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, PDF 1.5, SIDM, PCL XL 3.0
Media Type
Envelopes, transparencies, labels, plain paper, recycled paper, banner paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1500 - 5000 pages
Print server - Ethernet, Fast Ethernet - internal
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.3.9 - 10.6
Microsoft Certification
Works with Windows Vista
48.5 cm x 63.4 cm x 34.5 cm
Printer Type
Workgroup printer - LED - colour
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10 sec
Language Simulation
Colour Management Features
Application-based colour management, ICC Color Profiles
Media Handling
RAM
RAM Installed (Max)
128 MB / 728 MB (max)
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
148.5 mm x 182 mm
Max Media Size (Custom)
297 mm x 431.8 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 220 g/m²
400 sheets
Media Feeders
1 x automatic - 100 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 120 g/m² , 2 x automatic (optional) - 530 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 176 g/m²
Max Media Capacity
1460 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
1500 - 5000 pages
Print server - internal
Expansion Slots
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
Consumables Included
1 x toner cartridge (black) - up to 2300 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 2300 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 2300 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 2300 pages ISO/IEC 19752
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
570 Watt
Power Consumption Stand by / Sleep
200 Watt
Software Included
OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Web Print, OKI Gamma Utility, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Template Manager, OKI PDF Direct Utility, OKI Color Access Policy Manager
