Key features
- Low running costs
- Fast duplex printing at 34ppm colour/36ppm in mono
- Generous paper capacity up to 1690 sheets for large workgroups
- Prints on stocks up to 250gsm – heavier than any comparable printer
- Security features protect sensitive information and IP
- Store templates and documents on the device for all users to print without authentication (Shared Print)
- Citrix XenApp 7.6 compatibility - ideal for virtual network environment
Advanced connectivity
- Wireless Direct feature offers safe simultaneous connection of wired and wireless networking
- Gigabit Ethernet enables fast transfer of large colour files across the network
- Google Cloud Print 2.0 ready enabling printing on the move
- Optional Wireless LAN Module available
Cost and energy saving
- Print marketing materials in-house thanks to outstanding print quality and media flexibility
- Deep Sleep mode saves energy Auto-Off mode automatically powers down to less than 0.5W when not in use
- Toner Save to reduce cost when printing draft or internal documents
- Duplex printing reduces paper usage (optional on C712n)
- Free consumables recycling programme
- LED technology means no moving parts for a longer life
Designed for high-volume printing, the OKI C712n has a recommended monthly volume of 6000 pages, ensuring it meets the demands of busy work environments.
With a media handling system that supports sizes from A6 to A4 and types ranging from plain paper to envelopes, this printer is equipped to handle diverse printing needs.
Leveraging OKI ProQ2400 Multilevel image enhancement technology, the C712n delivers sharp, vibrant color and B/W printing at resolutions up to 1200 x 600 DPI.
Achieve productivity with fast printing speeds of up to 36 ppm for B/W and 34 ppm for color, complemented by quick first print out times of 8 sec for B/W and 9 sec for color.
- OKI C712n - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 29 kg
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1321 mm
- Min Media Size (Custom)
- 64 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 1321 mm
- Print Speed
- Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Automatic Duplexing
- Optional
- Interface
- USB 2.0, Gigabit LAN
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, ZIP, OCR-A, OCR-B
- Media Type
- Envelopes, plain paper, banners, postcards
- Total Media Capacity
- 630 sheets
- Media Handling
- 100-sheet multipurpose tray, 530-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 6000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11, Linux
- 3-year warranty with product registration
- 43.5 cm x 54.7 cm x 38.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- Optional
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 87 x scalable PCL , 80 x PostScript
- Barcodes
- Media Handling
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 1321 mm
- 64 mm x 127 mm
- 216 mm x 1321 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), Statement (139.7 x 215.9 mm), Folio (216 x 330 mm), 76.2 x 127 mm, 75 x 125 mm, 101.6 x 152.4 mm, 127 x 177.8 mm, 100 x 150 mm, 125 x 175 mm, 64 x 127 mm, 216 x 1321 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 64 g/m² - 250 g/m²
- 630 sheets
- Media Feeders
- Input tray: 1 - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Multi-purpose tray: 1 - 100 sheets weight: 64 g/m² - 250 g/m²
- Max Media Capacity
- 1690 sheets
- Output Trays Capacity
- 450 sheets
Duty Cycle
- 100000 pages
- 6000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, IPv6
- Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x, Secure Erase, MAC address filtering, IP filtering
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) , 4 x drum
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1300 watt
- Power Consumption Stand by
- 100 watt
- Power Consumption Sleep
- 1.2 watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Color Swatch Utility, OKI Color Correct, OKI Template Manager, OKI PDF Print Direct, OKI Network Card Setup, OKI Configuration Tool, OKI PS Gamma Adjuster, OKI Firmware Update Tool, OKI Profile Assistant, OKI Print Job Accounting
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 43.5 cm
- 54.7 cm
- 38.9 cm
- 29 kg
