OCZ Agility 3 SATA III solid state drives are designed and built to provide an exceptional balance of performance and value. The Agility 3 series implements the cutting-edge SATA 6 Gbps interface to deliver excellent sequential and random data transfer rates, significantly improving your computing experience over hard drives.
In addition to enhanced performance, an Agility 3 upgrade promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. With no moving parts, SSDs provide peace of mind with their superior durability and reliability. Unique and innovative, Agility 3 SSDs deliver a one-of-a-kind storage solution.
120GB Max Performance*
Max Read: up to 525MB/s
Max Write: up to 500MB/s
Random Write 4KB (Aligned): 50,000 IOPS
*Max performance achieved using Native SATA 6Gbps chipset. Please refer to product sheet for additional performance metrics
Available in 60GB, 120GB, and 240GB Capacities
MLC NAND Flash
Interface: SATA 6Gbps / Backwards Compatible 3Gbps
Native TRIM support
Seek Time: .1ms
Slim 2.5" Design
99.8 x 69.63 x 9.3mm
Lightweight: 77g
Operating Temp: 0°C ~ 55°C
Storage Temp: -45°C ~ 85°C
Low Power Consumption: 2.7W Active, 1.5W Idle
Shock Resistant up to 1500G
RAID Support
Compatible with Windows 7, Vista, XP 32-bit/64-bit, Mac OSX, Linux
MTBF: 2 million hours
3-Year Warranty
See The OCZ Agility 3 Solid State Drives In Action!
OCZ Agility 3 Series - SSD - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
TRIM support, S.M.A.R.T.
70 mm x 100 mm x 9.3 mm
77 g
3-year warranty
120 GB
2.5" x 1/8H
SATA 6Gb/s
70 mm
100 mm
9.3 mm
77 g
Performance
Internal Data Rate
525 MBps (read) / 500 MBps (write)
4KB Random Read
20000 IOPS
4KB Random Write
50000 IOPS
Maximum 4KB Random Write
85000 IOPS
Seek Time
0.1 ms (average)
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Linux, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
