Use Powerline 500, 1 Port to extend your wired connections throughout your home using your electrical wiring, with speeds up to 500Mbps. Whether you're extending your connections to your Smart TV, or game consoles, NETGEAR has a solution that makes it simple and easy. Additionally, the convenient design makes it easy to place without losing the use of your power outlet.
Expand Your Existing Powerline Network
Add new Powerline adapters easily. Backward compatible with 200 Mbps and 500 Mbps Homeplug AV products.
Game Consoles
Avoid lag and interference by using a wired connection with Powerline throughout your home. Simply plug into an electrical outlet and conect your console to the Ethernet port to get fast, wired Internet, so you can stay connected.
Smart TVs and Players
Whether you're connecting your TV, Blu-ray or media player, you can avoid the hassle of running extra network wires. No need to rely on WiFi to watch your favorites movies and TV shows. Connect your TV or media player to the POwerline and enjoy wired Internet instantly.
Use Your Plug. Don't Lose Your Plug.
The Powerline 500 + Extra Outlet lets you easily use an electrical outlet to gain an Internet connection. And you won't lose the use of that electrical outlet, since you can still plug a device in for power.
Key Features
- Extend your Internet to any power outlet
- Typical coverage up to 500 m2
- Extra outlet
- Compact, elegant design
- Convenient power outlet, filtered for better performance
- Pick-a-Plug LED identifies best outlet for optimal performance
