Back
Routers
NETGEAR Wireless-N 300 Router w/DSL Modem
Quicklinx:
72GGWS00
Mfr#:
DGN2200-100UKS
Gallery
Accessories
(1)
Back
Marketing description is not available.
NETGEAR DGN2200 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP, HTTP
Firewall protection, DMZ port, DoS attack prevention, content filtering, IDS, IPS, parental control, wall mountable, QoS, WPS, Multiple SSID support, ReadySHARE
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
AC 240 V (50 Hz)
Environmental Standards
ENERGY STAR Qualified
17.3 cm x 12.8 cm x 3.3 cm
300 g
Apple MacOS, Microsoft Windows 2000/ME/XP/Vista/7
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
TCP/IP
Routing Protocol
RIP-1, RIP-2
SNMP, HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, VCCI Class B ITE, CISPR 22 Class B, EN55022 Class B, FCC Part 15 B, RoHS, WEEE, CEC
Status Indicators
Port status, power, link/activity
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
AC 240 V (50 Hz)
ENERGY STAR Certified
Vertical stand, POTS filter
1 x network cable , 1 x phone cable
United Kingdom
Software Included
Drivers & Utilities
17.3 cm
12.8 cm
3.3 cm
300 g
10 - 90% (non-condensing)
Accessories
Other bundles (1)
C2G 2m USB 2.0 A/B Cable - Black
In Stock
£4.02
Quantity to buy of C2G 2m USB 2.0 A/B Cable - Black
