At 54 Mbps, this wireless 2.4 GHz 802.11b/g PCI card is much faster than existing 11 Mbps wireless networks and will supercharge the delivery of media-rich content to your desktop PC as never before. It easily handles huge digital video and MP3 files, firing them through your network at blazing speeds. It gives you continuous access to your home wireless router or office network, saves the time and expense of installing Ethernet cabling when you want to set up or expand a network, and makes it simple to relocate your desktop PC without rewiring. Moreover, it allows network users to wirelessly share a broadband Internet connection for access to corporate resources, the Internet, and e-mail all with the highest available level of industry standard WEP encryption security.
This high-speed 802.11g PCI card delivers large files in the blink of an eye up to five times faster than 802.11b, allowing wireless video streaming for the first time ever. Dynamic rate shifting according to environmental conditions achieves the fastest possible connections.
The card adds convenient mobility and reliable standards-based wireless connectivity to a network from a desktop PC via an 802.11b, 802.11g, or dual-band router or access point. It makes the most of your broadband connection, allowing network users to wirelessly share one IP address. The card quickly and easily networks employees for ongoing access to corporate resources, e-mail, and the Internet.
Secure 40/64 and 128-bit Wired Equivalency Protection (WEP) encryption allows for secure data transfer and increased shielding from wireless eavesdroppers. The card supports Virtual Private Network (VPN) pass-through for protected communication over the public Internet. It is simple to install and use.
Please note - this is not compatible with Windows 7
Customer reviews
Write a review for the NETGEAR WG311 54 Mbps Wireless PCI Adapter - network adapter here!
By
S Tweddle.
Posted
04/08/2007
Netgear WG311
By
AP IT Solutions.
Posted
26/10/2005
It does exactly what it says on the box
By
Anonymous
Posted
11/05/2004
Read all 14 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
