The NETGEAR N150 Wireless Router is a simple and secure way to share your high-speed Internet connection at Wireless-N speeds for surfing the Internet, email, online chat and Facebook. Easy setup with the Smart Wizard CD gets you up and running fast, while Wi-Fi Protected Setup gives you a secured connection at the push of a button. Compatiblity with Wireless-G networks allows hassle-free connection flexibility.
Surf, email, chat
Share your Internet connection
Smart Wizard™ -- easy setup
Free Parental Controls
Provides better wireless coverage than older Wireless-G routers
Extra performance boost when connected to Wireless-N devices
Surf, e-mail, stream music, play on-line games, and make Internet phone calls
Push 'N' connect can securely connect devices at the push of a button
Convenient on/off switch helps save energy when not in use
Efficient Energy Star compliant power supply
Packaging manufactured with at least 80% recycled materials
