Back
HomePlug
NETGEAR HOME THEATER INTERNET CONNECTION KIT
Quicklinx:
6KN6WS00
Mfr#:
XAVB1004-100UKS
Back
Marketing description is not available.
NETGEAR XAVB1004 - powerline adapter - desktop
Powerline adapter - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
200 Mbps
MAC addresses: 64
QoS, Push-and-Secure button
IEEE 802.3, IEEE 802.3u, HomePlug AV
13.7 cm x 10.2 cm x 2.8 cm
218 g
Apple MacOS X, Microsoft Windows Vista / XP / 7
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wired
Data Transfer Rate
200 Mbps
MAC addresses: 64
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, TUV, cUL, IEC 60950, UL 60950, CB, FCC Part 15 B, LVD, EMC Class B
Status Indicators
Line Properties
Line Coding Format
OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x HomePlug AV
Internal power supply
Powerline AV 200 Nano Adapter (XAV2101)
2 x network cable - 2 m
United Kingdom
13.7 cm
10.2 cm
2.8 cm
218 g
Limited warranty - 1 year
10 - 90% (non-condensing)
