            For a high-speed network on a small scale, nothing delivers likes these compact powerhouses. Equipped with five auto-sensing 10/100/1000 Mbps UTP ports, NETGEAR ProSafe GS105 switches give your network the capacity to handle huge workloads. If your network is configured to support jumbo frames, ProSafe GS105 switches will forward them, as well as honoring priority tags at both the layer 2 and layer 3 level. This means they move very large files across your network instantly, and keep the high priority traffic moving. Packed with ease-of-use features to simplify your networking experience, its trim design makes it an easy fit for a desk or mounted on a wall. The durable metal chassis protects interior working parts and the fanless design results in silent operation. Matched with NETGEAR's thorough testing, the ProSafe GS100 series switches provide long-lasting performance you can count on.
        Customer reviews
                Write a review for the NETGEAR GS105 5 Port Gigabit Switch    here!
            It just works
                By
                        David.
Posted
                30/11/2007
            Excellent value, no problems at all.
                By
                    Anonymous
Posted
                13/07/2007
            Fantastic gigabit switch for the price
                By
                        Nami IT Solutions Ltd.
Posted
                17/08/2007
                    Read all 6 customer reviews
            The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
