Boost the WiFi coverage in your home by adding the NETGEAR EX3800 AC750 Simultaneous Dual-Band WiFi Booster/Range Extender. With speeds up to 750Mbps and an extra Ethernet port, you can connect to speed for gaming and streaming via WiFi or a wired connection. Convenient wall-plug design lets you discreetly place the range extender where you need it, while the new pass-thru design lets you keep access to your outlet.
Key Features
- Simultaneous dual band WiFi speeds of up to 750Mbps.
- Provides an extra outlet to power additional devices.
- Extend 2.4 and 5 GHz WiFi up to 750Mbps and reduce interference.
- FastLane Technology to establish super high-speed connections.
- Convenient wall-plug design with extra noise-filtered power outlet.
- Ideal for online gaming and HD streaming on tablets, smart phones and TV.
- Connect a wired device like a console or a smart TV to your WiFi network.
