Hang on - your network will soar when it's hooked up to NETGEAR's FS605!
This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as five computers or peripherals to your Ethernet network.
You'll experience maximum performance for 10 or 100 Mbps devices with five ports that automatically sense the correct speed while Auto Uplink on the ports adjusts for the different types of Ethernet cables. The FS605's sleek case has lights on the front for easy monitoring. Installation into your home network couldn't be simpler and, once powered on, it begins cool and silent operation - without an internal fan.
Auto Uplink™ technology automatically adjusts to suit all your Ethernet cables
Every port automatically senses the right speed and duplex mode
Low power consumption, enabling these switches to run cool without a fan
Works with PCs, Macs, servers, printers & virtually any Ethernet device
Attractive, compact platinum design blends seamlessly into your home decor
Network Connectivity: 5 RJ-45 ports for 10BASE-T and 100BASE-TX
Status LEDs: Power, Speed and activity on each port
Customer reviews
Write a review for the NETGEAR 5-Port 10/100 Switch here!
Great Network Switch
By
Lee Thomas.
Posted
21/07/2007
good value stylish swtich
By
Anonymous
Posted
28/11/2003
great switch
By
Anonymous
Posted
20/05/2004
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
