            This product is a Genuine NEC Replacement Projector Lamp Unit, designed for use in the NEC LT380 Projector.
You never know when your service replacement lamp might fail, so it's smart to carry a back-up on business trips or keep a spare one at your presentation facility. This service replacement lamp from NEC is a lifesaver if your bulb burns out. This durable service replacement lamp will give you hundreds of hours of excellent, crisp, clear brightness.
