The PH1400U stacking setup provides 27,000 lm for typical rental/staging applications. Mounted on the easy adjust flight frame and easy setup by automatic camera system.
With WUXGA resolution and superb brightness levels and color ranges, your viewers will enjoy an outstanding visual experience.
Installation is easy, even in challenging venues
Motorized lens shift with vertical and horizontal adjustment and lens memory makes setting up the perfect installation image easy.
Time saving network control
It is designed for cost saving convenient maintenance and management of content and scheduling.
NEC PH1400U - DLP projector - no lens - 3D
DLP projector
3D Capable
Brightness
13500 ANSI lumens
Contrast Ratio
2000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens
No lens
Lens Shift Direction
Horizontal, vertical
Bulb type
2 x 465 Watt
Bulb life cycle
Up to 2000 hour(s)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 720p, 1080/60i, 1080/50i
AC 120/230 V (50 - 60 Hz)
1050 Watt
57.8 cm x 55.8 cm x 23.5 cm
40 kg
3-year warranty
DLP projector
3D Capable
Projector
Brightness
13500 ANSI lumens
Contrast Ratio
2000:1
Image Size
203 cm - 1270 cm
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 108 kHz
Bulb type
2 x 465 Watt
Bulb life cycle
Up to 2000 hour(s)
Picture in picture, 3D Reform technology, Edge blending, USB host function, picture by picture, Hollywood Quality Video (HQV), PJlink, Crestron RoomView, Geometric Adjustment, Intelligent Power Management, DICOM Simulation Mode, Direct Power Off, lens memory, Active 3D projection capability
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - BNC x 5 , 1 x DisplayPort - 20 pin DisplayPort , 1 x HDMI - 19 pin HDMI Type A , 1 x DVI-D - 24+1 pin digital DVI , 1 x composite video output - BNC , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 2 x USB 2.0 - 4 pin USB Type A , 1 x remote control - mini-phone stereo 3.5 mm
